LabWindows/CVI
CVI, when it chrats a char [] is it allways init to ""
When CVI creats a variable "char strHello[50]"  I always notice that the string (character array) is initilized to empty string.       I know this is not true in othe "C" compliers but is this true in CVI.      Are strings allways initilized to an empty string, even if string is in a structure.
(2,956 Views)
As far as I know, this is true for global variables (i.e. variables declared at module-level or declared in a include file), while this is not guaranteed for variables local to a function, even if embedded inside a structure.
(2,951 Views)
