LabWindows/CVI
CVI program won't start anymore
Our measurement application worked well on several PC's (Win7 32Bit, WinXp 32Bit).
But on 2 newer PC's (Win7 32Bit) the application won't start anymore.
The attached Error with the code R6030 shows up.
We found a workaround for the problem: run the application as administrator.
But after we installed a USB-driver, this workaround doesn't help anymore,
and the Error shows up every time.
We installed the environment (cvi-rt, etc...) with an distributed setup.
So the Versions of the components are the same on every PC.
Any ideas?
(3,386 Views)
Accepted by topic author Refur
Okay we solved the problem,
the cause was, the HP-Software, which was preinstalled on the PC's (the others were Dells)
After uninstalling the HP Security Suite our application works perfect.
I hope this helps other poor guys Smiley Happy
(3,370 Views)
