LabWindows/CVI
CVI profiler
i'm using CVI 7.1 and i would need some code profiler, to check performance of my code.
I need it for my DIO card PXI-6509, which i control by DAQmx
(3,543 Views)
Hi Michalkubik,
There is no code profiler in CVI, but the following resources should take you a long way to your goal:
Improving Performance of LabWindows/CVI Applications
Code coverge analysis
Are there any performance profile tools for CVI?
Performance Issues
does labwindows/cvi 7.0 have any performance profiling (code coverage, memory leaks) tools?
Cheers,
David Goldberg
Software R&D
(3,503 Views)
Hello AEDavid,
thanks for links. As it seems to be, the best way will be use some external compiler- maybe MSVC.
Michal Kubik
(3,448 Views)
