LabWindows/CVI
CVI distribution kit with command line or script
I do have a CVI project on which i generate a distribution KIT "manually".
What is the good way  if i want to automate it through a command line ?
For instance, is there any example on How to use  Active X control through CVI_AppCreateDistributionKit?
Or other method?
Thank you
(1,401 Views)
Hello
I think this article can help you in this case.
ActiveX Features That Are Supported in LabWindows/CVI - NI
Regards
(1,237 Views)
