LabWindows/CVI
CVI app : read values in registry key
Hello
I have written an CVI app., which should read values in registry key.
In my register base, the mask i want access is (for example) :
SYSTEM\\CurrentControlSet\\Control\\ProductOptions
« ProductType » = dword :00000028
SYSTEM\\CurrentControlSet\\Control\\Product01
« Data1 » = dword :00000102
SYSTEM\\CurrentControlSet\\Control\\Product02
«Data1» = dword :00000058
the function below shows me how retrieve the type and data for a specified
value name (Product Type) with an open registry key
(CurrentControlSet\\Control\\ProductOptions) . ok but i want to enumerate
differents subkeys of a specify key ???
for the example with the key « CurrentControlSet\\Control » the result will
be :
- ProductOptions
- Product01
- Pro
duct02
But i don't know how to do this.
Thanks for help.
Arnaud (France).
DWORD GetWindowsVariant(void)
#define MY_BUFSIZE 32 // Arbitrary initial value.
// Dynamic allocation will be used.
HKEY hKey;
TCHAR szProductType[MY_BUFSIZE];
DWORD dwBufLen = MY_BUFSIZE;
LONG lRet;
if(RegOpenKeyEx(HKEY_LOCAL_MACHINE,
TEXT("SYSTEM\\CurrentControlSet\\Control\\ProductOptions"),
0,
KEY_QUERY_VALUE,
&hKey) != ERROR_SUCCESS) return RTN_ERROR;
lRet = RegQueryValueEx(hKey,
TEXT("ProductType"),
NULL,
NULL,
(LPBYTE)szProductType,
&dwBufLen);
RegCloseKey(hKey);
....maybe use KEY_ENUMERATE_SUB_KEYS in RegOpenKeyEx and use
RegQueryMultiplesValues ??
(5,334 Views)
Damned, no answer... I'm looking for the same.
(5,031 Views)
RegQueryInfoOnKey returns the number of values (and the max value name length, so you can allocate an appropriate buffer) that exist for a particular registry key. You can then call RegEnumerateValue once for each value to get the actual names and data.
Mert A.
(5,021 Views)
That what I thought, but RegEnumerateValue seems to list only values, not subkeys.
I wanna get subkeys under "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI", and RegEnumerateValue doesn't give anything 😞
Perhaps there's a mistake in my code. I'm going to take another look.
(4,999 Views)
I'm probably mistaken but it seems to be impossible to enumerate subkeys with NI toolbox (CVI 7.0).
A good clue : http://msdn2.microsoft.com/en-us/library/ms724256.aspx (but it's not clear, two parameters are IN/OUT !)
Here is a good exemple using SDK with explanation (I hope usefull). I've also attached the file.
#include<windows.h>
void main(void)
 int  iStatus = 0;
 HKEY  handleKey = NULL;
 char  tcSubKeyName[255];
 int  iSubKeyBufferLen = 255;  // Very important for RegEnumKeyEx calling, you need to give it tcSubKeyName buffer lengh. After you'll get returned lenght
 char  tcClass[255];
 int  iClassBufferLen = 255;
 FILETIME fsLastWriteTime;
 iStatus = RegOpenKeyEx(HKEY_LOCAL_MACHINE, "SYSTEM\\CurrentControlSet\\Enum\\PCI", 0, KEY_READ, &handleKey);
 // RegQueryInfoKey() may give interesting information about sunkeys
 if(handleKey != NULL)
  // Reading first one
  iStatus = RegEnumKeyEx(handleKey, 0, tcSubKeyName, &iSubKeyBufferLen, NULL, tcClass, &iClassBufferLen, &fsLastWriteTime);
  // ... should add no error test to detect the end
  // Reading second one
  iStatus = RegEnumKeyEx(handleKey, 1, tcSubKeyName, &iSubKeyBufferLen, NULL, tcClass, &iClassBufferLen, &fsLastWriteTime);
  // Readin...    now you should make a loop 😉
  RegCloseKey(handleKey);
  handleKey = NULL;
(4,984 Views)
It looks like I misunderstood the question. It appears that you are correct about the CVI Toolbox Registry functions. I'll put in a suggestion to create a RegEnumerateKey function. I'm surprised it isn't already there.
Mert A.
(4,973 Views)
