LabWindows/CVI
CVI & Driver Instrument
Hi guys. My problem is to see the Rigol DSA1030A as instrument in CVI. I have connected it via USB and following the guide I have downloaded the IVI driver where I haven't found any *.fp file.
Yestarday talking with a NI engineer he suggest me to use the VISA...but I have no idea. Is there any guide where I can read something? or by the way can you help me with this problem?
Thank you
(4,485 Views)
I've never used any Rigol instrument, but you may possibly find some informations and link in this document from Rigol website.
(4,480 Views)
To be honest I have already used this instrument with labview without problems.
Is it possible that they haven't rereleased any driver for CVI?
(4,477 Views)
As I said, I never used Rigol instruments so I don't know the answer to this question.
In the document linked by Wolfgang in your other thread there indeed is a log (report.html) that refers to LabVIEW VIs being generated out of the CVI driver, so it should be available somewhere... There is also a .msi installer: did you tried running it? Has it installed some particular software or document?
(4,473 Views)
unfortunatelly seems not. I tried to write directly to rigol to see if they can help me. I hope they'll reply soon.
thank you by the way for your interest and help.
If i reach a solution I'll write it here.
(4,471 Views)
