LabWindows/CVI
CVI aborts with no warning when compiling
When I compile a simple instrument driver with the CTRL-K shortcut in CVI 2009 (9.1) it aborts CVI without warning Smiley Surprised
No popup, no nothing.
All I had done was delete a typedef in the driver file for a structure containing GPIB configuration info.
After it did it about 5 times in a row it finally stopped when I included a header file that re-established the typedef for the GPIB struct.
So the problem was that this typdef appeared as a parameter type in a prototype in another header file, and when I eliminated the definition it caused the abort. The abort was immediate, I have to think it was something wrong in the preprocessor.  I do not have precompiled headers checked in the build options.  I am using the standard CVI compiler.
Weird, huh.
Menchar
(3,783 Views)
Hi menchar,
Do you have a simple example project that exhibits this behavior. Based on your explanation, it looks like a bug we might have to report. If you can give me a simple example, I can reproduce the issue and subsequently submit a corrective action request to our R&D team. Is this possible?
Raj
(3,746 Views)
Some how I knew you'd ask for that Smiley Wink
I don't have a simple case.
It was absolutley repeatable, I couldn't believe it when it first happened.
I had something like this in the driver file:
typedef struct _GPIBConfig {
  DWORDBus;
} GPIBCONFIG, * LPGPIBCONFIG;
and in a header file I had a prototype that used the typedef as a parameter type:
headerfile.h
INT myFunc (GPIBCONFIG config);
When I eliminated the typedef  from the driver file, I got the crash.
When I added another header that defined the GPIBCONFIG struct, the crashes stopped.
Restarting CVI did not cure the problem.  When I restarted, CVI did a popup saying the previous instance of CVI had been stopped abnormally.   I recovered the project per the popup.  Then when I restarted and recompiled, it crashed again, but when I restarted I didn't get the popup.
 Menchar
(3,744 Views)
Hi menchar,
I created a simple project on my end.
Added a function tree and a function panel window.
Created the .c and .h files for the function panel.
Added them to the project.
Added the following line in the instrument header file.
  DWORD Bus;
Compiled the code. It compiled successfully.
Added another header file to the project and inserted the following line under Global functions.
int myFunc (GPIBCONFIG config)
I removed the typedef struct code from the instrument header file.
Is there something I am doing incorrectly here? Is there anything else that you would have me try to reproduce this issue?
Raj
(3,708 Views)
When I said "driver" I meant a C code module that I use as an instrument driver, without a function panel.    It's not a "driver" in any formal sense.
The crash occurred when the typedef was in the instrument module itself (not a header file) and I deleted it from the module.
It may have been some perverse combination of editing and file manipulation that showed the problem ... if I see it again I will try to capture the sources so that you can try to diagnose it.
I had never seen this type of problem before despite using CVI 2009 for many hundreds of hours.  I wonder if it has something to do with the changes made to CVI to support precompiled headers, though I was not using precompiled headers at the time.
So I wouldn't do anything more with it for now if I were you, let's see if it happens again.
Menchar
(3,704 Views)
