‎01-23-2014 02:56 AM
When I do the convertion of CVI2010 Project in VS2008 IDE, a dialog which says "Cannot find the VXIpnp Directory." pops,how to deal with this problems? Thanks!
‎01-31-2014 07:24 AM
Hello Simon!
Did you install the IVI Compliance Package?
‎02-10-2014 11:51 PM
Hello Johannes_T! Thank you for reminding me,when I was installing the CVI2010,drivers were not installed.But where can I download the IVI Compliance Package which is matching with the installed CVI version(CVI 2010)?
‎02-11-2014 02:17 AM - edited ‎02-11-2014 02:18 AM
You can install the ICP from the following location: http://www.ni.com/download/ivi-compliance-package-4.4/2589/en/
Note, that if you also want to use the IVI Configuration utility, MAX also needs to be installed, which you can download from: http://www.ni.com/download/ni-device-drivers-2013.02/3802/en/
