LabWindows/CVI
CVI Image_control
I want to use the get_image in CVI and set _mage but in
The function library without these two functions
(3,272 Views)
I cannot find such functions in my install of CVI: are you using some additional toll like NI-Vision or IMAQ or something else that install this instrument?
If so, I cannot help you since I'm not using Vision in my activity: let's see if somebody else can answer your question.
In the meanwhile, you should list the software and tools you are using, including the version installed of each of them, so that the correct answer can be given.
(3,240 Views)
I want to use  IMAGECTRL control to dispaly image
(3,233 Views)
 my  cvi  is 2013 version
(3,232 Views)
