LabWindows/CVI
CVI Excel Instrument Bug
Hi
I did not know where you post this, but i came across a major bug in the excel report instrument.
I wanted to set the cell range attribute and there was no attribute id's.
I am currently using Labwindows/CVI 9.0.1.
I have attached a screen shot .
Help share your knowlegde
(3,345 Views)
Hi Shako,
Can you check to see if the file c:\program files\national instruments\cvi90\toolslib\activex\excel\excelreport.sub exists in your CVI installation? If it does, can you make sure that you are including excelreport.fp in your project from that same folder?
Luis
(3,321 Views)
Yeah, that exactly looks like a sub-file-missing issue.
I've been there 🙂
If you copied the fp in your project copy the sub file, too...
S. Eren BALCI
IMESTEK
(3,298 Views)
