I use CVI 2015.
I have an Automatic tester wrote in CVI.
Recently I noticed that when i use in script that my program runs, a delay (for example 5 seconds), the delay time is bigger, and can be 13 seconds.
I ran an older version of the Tester application, and the delay time is also 13 seconds.
Do you have an idea about this?
Recently we moved fro PCs run WIN7 to WIN10, maybe it's related?
Thanks in advance,
在 01-12-2020 02:50 PM
What code do you use for the delay ? The Delay() function ? A Timer callback ? How busy is your program ? How busy is the rest of the CPU ? I could recommend using async timers, but I feel that some more info is needed first.
在 01-12-2020 11:57 PM
Hi gdargaud,
I manged to understand the problem.
In the script I used there were extra characters that caused the delay.
Thank you for your efforts.
