LabWindows/CVI
CVI Application as WIN-Logon-Shell in registry
hi all, think this is a WIN-internal: I built a CVI 8.0.1-solution - runs ok. now I want to make sure that only this application runs on the system and wrote this into the registry-key (Microsoft\WindowsNT\logon\shell) as often described in the forum. functional it also runs ok. but if the application starts the graphical presentation of the splash and mainwindow are not updated like if it runs as a normally Win-Application with the explorer in background. So the user doesnt see whats happening while initialization is running. any idea where to change this behaviour ? thanks and best regards Simon
(2,869 Views)
When you build an Win32 Application - then in template you had included important classes and librarys for GUI in Windows. So you should look in these files (headers, librarys) then you should find the differences between console application (service) and win32 applications...
Please add here your code - perhaps i find the right place/code for your problem...
Best Regards
(2,842 Views)
