LabWindows/CVI
CVI 8.5 __FUNCTION__ Macro missing
I just installed CVI 8.5 and tried to compile one of our projects that is using the __FUNCTION__, __FILE__ and __LINE__ macros for creating error messages. The __FILE__ and __LINE__ macros are compiled, but the __FUNCTION__ macro is not found by the compiler and creates an error.
Steven
Message 1 of 29
(12,395 Views)
__FUNCTION__ (or more properly __func__) I think is a C99 feature, although it was implemented in other compilers, of course, previously. CVI is not C99 compliant - as has been discussed before.
Martin
Certified CVI Developer
Message 2 of 29
(12,389 Views)
I don't quite understand that the __FUNCTION__ macro is not working, because it worked well in CVI 8.1.1.
Steven
Message 3 of 29
(12,410 Views)
Steven,
As Martin mentioned, the __FUNCTION__ macro is not part of the ANSI C 89 standard. It is part of the C99 standard, and CVI isn't C99-compatible. What happened in 8.5 was that a handful of the features that comprise the C99 standard were added (note: for those of you who have shown interest in C99 and CVI, please be aware that CVI 8.5 is nevertheless still not C99-compatible).
Because code that uses C99 features might not be compatible with other C compilers, in order to use any of the C99-specific features of CVI 8.5, you will have to add a new pragma to your code:
   #pragma iso_9899_1999
Since __FUNCTION__ is really a C99 feature, it is now also grouped with the other features that require the use of this pragma. Actually, to be more precise, the C99 standard calls for "__func__", not "__FUNCTION__". But both should work in CVI 8.5. So, to answer your question directly, yes you can continue to use __FUNCTION__ but you'll have a line with this pragma somewhere above the use of the macro.
In case anyone is interested, these are the other features that are present in CVI 8.5, the use of which is governed by this pragma:
1. Declaring variables in the middle of a block. For example:
    int i = 1;
    printf ("%d", i);
    int j = 2;
    printf ("%d", j);
    for (int k = 0; k < i + j; ++k)
        printf ("%d", k); /* k is out-of-scope after the for-loop */
    printf ("%d", i + j);
2. Macros with variable arguments. For example:
     #define debug_printf(format,...) fprintf (stderr, format, __VA_ARGS__);
3. Allocating memory on the stack (alloca call).
4. Support for the long long data type (this is functionally identical to the already existing __int64), and its associated functions (strtoll, lldiv, etc...)
Luis
Message 4 of 29
(12,380 Views)
Is it possible to make use of  #pragma iso_9899_1999  depending on the CVI version?
How can be used in combination with _CVI_ (850) macro defined by CVI?
Message 5 of 29
(12,301 Views)
Solution found:
#if defined (_CVI_) && (_CVI_ > 850)
#endif
Message 6 of 29
(12,261 Views)
Does 8.5 have anything for IEEE 1754 support?    With CVI most everyone is horsing floating point values around a lot and C99 offers some refinements that are worthwhile and I wouldn't think all that hard to implement.
Menchar
Message 7 of 29
(12,234 Views)
Menchar,
Could you be more specific about what those enhancements are? My copy of the C99 standard does not mention IEEE 1754. Do you mean maybe IEEE 754?
Luis
Message Edited by LuisG on 11-26-2007 03:42 PM
Message 8 of 29
(12,227 Views)
Luis -
Yup, 754-1985 it is.
Menchar
Message 9 of 29
(12,224 Views)
Thanks a bunch for the information about the C99 enhancements, but can somebody please tell me why I have to stumble upon this by pure chance here in the forum instead of reading about it in the release notes? Isn't that what the notes are for, for deity's sake? On the bright side, these are exactly the C99 features I had on the wish list I gave to an NI developer earlier last year 🙂
Message Edited by MarcelK on 01-09-2008 02:48 PM
Message 10 of 29
(11,728 Views)
