LabWindows/CVI
CVI 8.0 Error Message
Hello !
When calling a function panel in CVI 8.0 with CTRL+P I get the following error message:
"An error occured while reading th function panel customization file.
Error message:
The DLL version does not match the import library".
Currently I also have older CVI versions on my PC (from 5.5 to 7.1) - to be able to compile older projects for cutomers who have older runtime engines on their computers.
It seems, in some way something is mixed up ...
How can I fix this problem ? Using the repair function together with my CVI 8.0 installation CD didn't improve the situation !
(2,969 Views)
Which FunctionPanel are you using, when you get this error?
(2,945 Views)
With ANY function panel ! The message appears always I want to use a function panel. After the message has be shown I can see the function panel. But when I want to view the function description or the description of a parameter the HTML source code is visible. Perhaps the help-View is the cause for the problem ? When closing the function panel, error messages appear again.
Thank You!
(2,941 Views)
