LabWindows/CVI
CVI 2013f1 Error: The compiler has run out of memory.
Hi again,
#pragma pack(push,1)
typedef struct
  char   sub_c;
} SUBSTRUCT;
#pragma pack(pop)
#pragma pack (push,8)
typedef struct
  char c;
  SUBSTRUCT sub1;
  struct
    int i;
  } sub2;
} BUGGY_STRUCT_AGAIN;
#pragma pack (pop)
BUGGY_STRUCT_AGAIN s = {0};
int main (int argc, char *argv[])
  return 0;
fails to compile, too.
Even with f1 patch.
/* Nothing past this point should fail if the code is working as intended */
(4,037 Views)
Hello CVI-User,
This appears to be a bug in our run-time checking. I have opened bug #450292 to track it and as a workaround I could suggest disabling run-time checking or using #pragma pack (push,8) only if necessary.
= Nelu F. || National Instruments.
(4,028 Views)
CVI-User,
Are you okay with the workarounds suggested by Nelu until we can fix the issue in the next release?
Jonathan N.
(3,892 Views)
