LabWindows/CVI
CVI 2013 compiling slow
Is it normal that compiling a project in debug mode takes much more time in CVI 2013 than in CVI 2010?
1'23 minutes versus 0'40 minutes.
When I recompile the project in CVI 2013 without any change to the source code it takes again 1'23 minutes in CVI 2013 versus 5s in CVI 2010.
Is there a setting somewhere which improves compiling speed in CVI 2013?
Message 1 of 11
(6,740 Views)
It depends on the project...
My impression is that compilation of large files is significantly slower, I had reported an example of a factor of more than five, which was later confirmed by NI
Message 2 of 11
(6,736 Views)
Hello Bertrand_ENAC,
LabWindows/CVI 2013 supports concurrent compilation, which means that you can improve the compile time of large files by splitting them into smaller files. I personally think that each file should have no more than 10k lines of code.
= Nelu F. || National Instruments.
Message 3 of 11
(6,572 Views)
In fact I have large files in my project. One of them has 18000 lines.
I followed your advice and reduce the size of this file to 13000 lines by swaping some code into new files.
I got an imrpovement but it's still disappointing.
With CVI 2010 entering a new empty line to that file gives a compilation time of 12s.
With CVI 2013 entering a new empty line to the file before change (18000 lines) gives a compilation time of 1mn 30s
and with the modified file (13000 lines) it takes 1mn.
So for the time being I will continue to work with CVI 2010 in order to avoid a heart attack.
It's a pitty that a new version is slower than a previous one. I hope this will be imrpoved in the future.
Best regards
Message 4 of 11
(6,194 Views)
It sounds like your project is compiling really slow. Do you make use of the concurrent compiles option under Build Opions > Build Process Options?
In order to speed up the process, you could disable run-time checking from Build Options > Configuration Options. You could also try to reduce the number of lines per file even further; you should get better results.
Ultimately, you could send us the project to analyse it by uploading it to ftp.natinst.com/incoming. It may be the case that the compiler is slower due to some constructs you're using. Is the memory usage high during compilation?
Message 5 of 11
(6,190 Views)
I double-checked and the location is ftp://ftp.ni.com/incoming, not ftp.natinst.com.
We look forward to hearing from you,
Message 6 of 11
(6,171 Views)
Number of concurent compiles is: CPUs (4)
When going from "Standart" debugging to "No run-time checking" and adding or removing an empty line to the lagon.c file the compiling time goes from 55s to 14s.
I have uploaded the projetc to your ftp. The name is "Test ELISE-GP CVI 2013"
Thank you for your support.
Bertrand
Message 7 of 11
(6,146 Views)
Thank you for sending us the project. We will investigate it and get back to you.
Message 8 of 11
(6,140 Views)
I have reproduced the slowness and opened bug 445424. It will be investigated further, to determine the root cause and possible fix.
Thank you for your feedback,
Message 9 of 11
(6,053 Views)
Hello Nelu,
actually I was hoping that this issue is already tracked...  (bug report 422103)
Message 10 of 11
(6,049 Views)
