LabWindows/CVI
CVI 2009 Build Distribution: create shortcuts
When I edit the Build Distribution settings I want to install my application under C:\Program Files\myFactoryDir\myAppDir, so in the "Edit Installer" window I use the "Files" tab to modify "Installation Files & Directories" as I need.
Then I want to create the following shortcut:
[Start>>Programs]\myFactoryDir\myAppDir\myApp.exe
but I'm not able to specify "[Start>>Programs]\myFactoryDir\myAppDir" as Destination Directory (in the menu ring, only [Start>>Programs]\myAppDir is available).
Is there a way to do this in CVI 2009 (as I'm used to do with LabVIEW)?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(4,499 Views)
Hi Vix,
After you added the shortcuts, go back to Files tab.
Under Installation Files & Directories you will see the shortcut folders listed. Right-click on them to add subdirectories.
Later in the Shortcuts tab, you can select this new folder.
Hope this helps,
Message Edited by ebalci on 30-04-2010 05:24 PM
S. Eren BALCI
IMESTEK
(4,486 Views)
I don't want to create the shortcut inside one of the installation subfolders (I can do this following your steps).
I want to create the shortcut under Start >> Program Files >> myFactoryDir, and I can't find this item in the Shortcuts tab
Vix
Using LV from 7
(4,477 Views)
Vix,
ebalci is correct. You need to create the subdirectory in the Files tab, under the{Start>>Programs] folder, so that this destination directory is available to you in the Shortcuts tab. Actually, you shouldn't even have to do a thing in the Shortcuts tab if you keep the initial shortcut folder from the Files tab and place it under the appropriate subdirectory. Like this:
(ignore the name of my .exe; I didn't want to change the files in my project)
Message Edited by LuisG on 04-30-2010 11:55 AM
(4,464 Views)
Accepted by topic author vix
Actually, please ignore the previous screenshot. It looks like I misunderstood where you wanted to place your shortcut. But it's even easier then, since all you should need to do is to rename the shortcut folder in the Files tab:
(4,455 Views)
