04-09-2018 12:49 PM
Is it possible to create custom made command buttons and use them in LabWindows CVI.
I am not talking about picture buttons. I tried those and you are very limited making the shape of the button. You can put a picture inside the button but you can not change the shape.
Solved! Go to Solution.
04-10-2018 02:46 PM
Hi bobby_y,
Does your main question have to do with being able to resize the picture button? If so, under control appearance, you can click the Image button and open up the Edit Pictures window as shown below. You should be able to change the Fit Mode setting to allow the picture button to size the image to the control
04-11-2018 10:35 AM
No it does not. I know how to change the size of a button. I need to create custom made buttons. The closest I got was to use picture buttons. But they have sharp edges and the
picture does not cover all the button. you can still see the edges.
04-12-2018 04:43 AM - edited 04-12-2018 04:43 AM
The button itself can be painted in transparent so that is shows only the picture. The highlight when it is active, though, will continue to be the overall rectangle.
Painting in transparent can be a problem if you have windows visual styles enabled, but there is a trick for that if you need to.
04-13-2018 12:14 PM
bobby_y: I'm intrigued by your question. To clarify, exactly what features are you looking for? You mention the edges but it is still not clear. For example:
I'm interested because some of these features can help make a UI look more modern or fit better with another suite of software. I'm often asked to make things look ... hmmm how shall I say it ... less like instrumentation.
04-13-2018 03:56 PM
I have been using CVI for over 15 years now and have been trying to use it every where I can. But unfortunately when I compare the button, icons or anything graphic, it does not come close to what is out there. Now days the icons and buttons used in applications are very modern, sharp and pleasing. The CVI graphics is really outdated. It can be used for industrial applications but not for VIP and high end visual applications.
Have you seen the buttons and icons used in home display panels. These panels are used to communicate with stereo system, TV, lights and so on. The graphics and icons are very nice and pleasing. Even the background seems to be a moving cloud.
So I am trying to somehow use CVI buttons to create a similar effect. But have not been able to.
10-19-2018 10:33 AM
I was able to do this with a couple tricks. I generated a useless arrow using PaintShop Pro with a transparent background. While the picture was active, I selected it. Then I copied it into the NI Icon editor window using 256 x 256 - 32 bit color. In LW, I created a picture command button with a transparent background, then loaded the icon file into it, and the rectangular white space does not show up on the panel. When clicking on the arrow, it moves down and to the right a few pix, but no shadowing occurs. The trick I believe is to eliminate the surrounding white space. Because I used an airbrush setting for the black outline, there are white pixels within that path. I would think clean lines would should show up clean.
10-30-2018 02:20 PM
Thanks.
I will try it
