LabWindows/CVI
CTRLARRAY SetCtrlAttribute function issue
I have multiple control types in a ctrlarray (textbox, leds, strings, buttons...).  I am trying to enable/disable them using a check box and the SetCtrlAttribute function.  I get the resource ID
TESTBED_1=GetCtrlArrayFromResourceID (panelHandle, CTRLARRAY_2);
then am trying to DIM all items in the array using
SetCtrlAttribute(PANEL,TESTBED_1,ATTR_DIMMED,1);
it does not function?  can this be down or do I need to DIM them individually since they are different ctrl types?
(3,222 Views)
Accepted by topic author Joncombat
You need to use SetCtrlArrayAttribute to set an attribute on an array of controls, not SetCtrlAttribute, which is used only with single controls.
One other thing... you need to pass the same panel handle to SetCtrlArrayAttribute that you pass to GetCtrlArrayFromResourceID (in your code snippet that's "panelHandle", not "PANEL").
Luis
(3,192 Views)
That did it!  Thank you!
(3,179 Views)
