LabWindows/CVI
CP210xManufacturingDLL.h
I am developing a production line test system that includes setting the PID, VID & serial number of a Silicon Labs CP2102 USB - UART bridge.
Silicon Labs have a DLL with exported header and lib files.
However, CVI (V7.0.0) will not compiler the header; producing the following error;
"CP210xManufacturingDLL.h"(166,31)   Illegal initialization for parameter 'bConvertToUnicode'.
CP210xDLL_API
CP210x_STATUS
WINAPI
CP210x_SetSerialNumber(
 HANDLE cyHandle,
 LPVOID lpvSerialNumber,
 BYTE bLength,
 BOOL bConvertToUnicode = TRUE        <<<<<<<<<<<<<<< This line
Removing the initalization removes the compiler error but will probably cause other errors.
Is there a bettor solution?
I have included "windows.h" before the dll header.
Cheers,
John C
(4,023 Views)
As long as you include all parameters to the dll function when you call it from CVI there should not be a problem.
JR
(4,019 Views)
Hi JR,
I see your point - thanks.
John C
(4,015 Views)
Hi, Johnc
Can you tell me how to slove this problem?
Thanks.
SCC
(3,523 Views)
