LabWindows/CVI
CNVString
I am not able to get strings using the network variable library.
Can anybody solve may problem ?
Thank you in advance.
Paolo
EXAMPLE :
WRITER
#include <windows.h>
#include <ansi_c.h>
#include <cvinetv.h>
#include <cvirte.h>
#include <userint.h>
#include "Writer.h"
#include <utility.h>
// Macros
#define errChk(f) if (error = (f), error < 0) goto Error; else
//#define DOUBLEDATA  1
static int panelHandle;
char message [50];
double doubleValue;
CNVWriter writer = 0;
CNVData  data = 0;
// Entry-point function
int main (int argc, char *argv[])
 int error = 0;
 int status = 0;
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1; /* out of memory */
 if ((panelHandle = LoadPanel (0, "Writer.uir", PANEL)) < 0)
  return -1;
    // Create a buffered writer
#ifdef DOUBLEDATA
 //    errChk(CNVCreateBufferedWriter(NETWORK_VARIABLE_PATH, 0, 0, 0, 64, 5000, 0, &writer));
 errChk(CNVCreateWriter ("\\\\localhost\\paolo\\doubleValue", 0, 0, 1000, 0, &writer));
#else
 errChk(CNVCreateWriter ("\\\\localhost\\paolo\\stringa", 0, 0, 1000, 0, &writer));
#endif
#ifdef DOUBLEDATA
 status = CNVCreateScalarDataValue (&data, CNVDouble, 123.456);
#else
 status = CNVCreateScalarDataValue (&data, CNVString, "");
#endif
 DisplayPanel (panelHandle);
 RunUserInterface ();
 DiscardPanel (panelHandle);
Error:
    // Cleanup
    if (data)
        CNVDisposeData(data);
    if (writer)
        CNVDispose(writer);
    // Cleanup Network Variable Library
    CNVFinish();
    // Report error
    if (error < 0)
        fprintf(stderr, "\n%s", CNVGetErrorDescription(error));
        fflush(stdin);
        fgetc(stdin);
 return 0;
int CVICALLBACK QUITBUTTON (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 switch (event)
  case EVENT_COMMIT:
   QuitUserInterface (0);
   break;
 return 0;
int CVICALLBACK CB_Timer (int panel, int control, int event,
 int status = 0;
 switch (event)
  case EVENT_TIMER_TICK:
#ifdef DOUBLEDATA
   GetCtrlAttribute (panel, PANEL_DOUBLE, ATTR_CTRL_VAL, &doubleValue);
     status = CNVSetScalarDataValue(data, CNVDouble, doubleValue);
   status = CNVWrite (writer, data, CNVWaitForever);
#else
   GetCtrlAttribute (panel, PANEL_MESS, ATTR_CTRL_VAL, message);
     status = CNVSetScalarDataValue(data, CNVString, message);
#endif
   break;
 return 0;
READER
#include <cvirte.h>
#include "Reader.h"
// Macros
CNVReader reader = 0;
CNVData  data = 0;
double doubleValue = 0.0;
char message [100];
 int error = 0;
 int status = 0;
 if ((panelHandle = LoadPanel (0, "Reader.uir", PANEL)) < 0)
  return -1;
#ifdef DOUBLEDATA
 errChk(CNVCreateReader ("\\\\localhost\\paolo\\doubleValue", 0, 0, 1000, 0, &reader));
#else
 errChk(CNVCreateReader ("\\\\localhost\\paolo\\stringa", 0, 0, 1000, 0, &reader));
#endif
#ifdef DOUBLEDATA
#else
#endif
Error :
    // Clean up
    if (reader)
        CNVDispose (reader);
 return 0;
 switch (event)
  case EVENT_COMMIT:
   break;
 return 0;
 int status;
 switch (event)
#ifdef DOUBLEDATA
   status = CNVRead (reader, 1000, &data);
   status = CNVGetScalarDataValue(data, CNVDouble, &doubleValue);
   SetCtrlAttribute (panel, PANEL_DOUBLE, ATTR_CTRL_VAL, doubleValue);
#else
     status = CNVGetScalarDataValue(data, CNVString, message);
   SetCtrlAttribute (panel, PANEL_MESS, ATTR_CTRL_VAL, message);
#endif
   break;
 return 0;
(4,097 Views)
After briefly looking over your code, I think your main problem is that you are trying to get the string value into a buffer, but the function expects you to pass the address of a pointer. Afterward, you have to free the memory the function allocates to store the string using CNVFreeMemory.
Your code:
char message[50];
Correct code:
char *message = 0;
status = CNVGetScalarDataValue(data, CNVString, &message);
// use message
CNVFreeMemory(message);
Hope this helps,
-alex
(4,084 Views)
Sorry ! My fault !
Hope to be more helpful next time.
Thank you
Paolo
(4,070 Views)
