LabWindows/CVI
CM Synergy LabWindows CVI interface available
Does LabWindows interface with CM Synergy? I need to do a comparison between VIsual Source Safe and Synergy.
(5,802 Views)
I believe so, because some developers (where I work) are using CM Synergy for source control of LW-CVI code.
(5,800 Views)
How easy is it to integrate with LW/CVI? I like the integration with Source Safe and am wondering about how it works with Synergy.
(5,789 Views)
Hello ljstrick,
Regarding how easy Synergy is to use with CVI code vs. SourceSafe, I wouldn't be able to answer, but LabWindows/CVI is compatible with source code control providers that support the Microsoft Source Code Control Interface (MSCCI).  Last I heard, Synergy doesn't support MSCCI out of the box, so you have to configure it using the steps decribed in the following KnowledgeBase (even though it's TestStand specific).
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(5,763 Views)
Hi Wendy,
Do we need obligatorily TestStand to use Telelogic' S CM Synergy with LabWindows CVI?
Jean-Noel
(5,710 Views)
Hi Jean-Noel,
No, you do not need TestStand for this.  You can use CVI code directly with Synergy.
Ray
(5,701 Views)
