LabWindows/CVI
CIN compiling error as following!!
I have add the command in projiect seting like"C:\Program Files\National Instruments\LabVIEW 6.1\cintools\ $(TargetName)-d $(WkspDir)\$(OutDir)" and "
$(OutDir)$(TargetName).lsb",but still get the error! What should i do??
--------------------Configuration: VI_name - Win32 Debug--------------------
Performing Custom Build Step on .\Debug\VI_name.dll
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
Error executing c:\winnt\system32\cmd.exe.
VI_name.dll - 1 error(s), 0 warning(s)
(3,008 Views)
Dear gpibssx,
Please do not post your questions to multiple forums in Developer Exchange. To see an answer to this questions, go here.
(3,008 Views)
My first guess based on the error is that you need to make sure that you have quotes around any path that contains spaces, otherwise the first space is take as the end of the string.
Hope that helps,
Juan Carlos
N.I.
(3,008 Views)
