LabWindows/CVI
CFTV BOARD
I´m trying to use a xv2003.ocx of CFTV board with labwindows.
I did the activex control, but I have a doubt in a function OpenSlot.
As a code:
#include <cvirte.h>
#include <userint.h>
#include <windows.h>
#include "XV2003.h"
#include "TESTE.h"
static int panelHandle;
int status, error;
short int dev, slot;
static CAObjHandle obj;
static CAObjHandle pic;
int main (int argc, char *argv[])
 if (InitCVIRTE (0, argv, 0) == 0)
  return -1; /* out of memory */
 if ((panelHandle = LoadPanel (0, "TESTE.uir", PANEL)) < 0)
  return -1;
    CA_InitActiveXThreadStyleForCurrentThread (0, COINIT_APARTMENTTHREADED);
 SetCtrlVal(panelHandle, PANEL_LED, 0);
 DisplayPanel (panelHandle);
 RunUserInterface ();
    if (!obj)
        CA_DiscardObjHandle (obj);
        obj = 0;
 DiscardPanel (panelHandle);
 return 0;
int CVICALLBACK sair (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 switch (event)
  case EVENT_COMMIT:
   XV2003Lib__DXv2003Stop (obj, NULL);
   XV2003Lib__DXv2003CloseVideo (obj, NULL, dev);
   XV2003Lib__DXv2003CloseSlot (obj, NULL, slot);
      obj = 0;
   QuitUserInterface (0);
   break;
 return 0;
int CVICALLBACK liga (int panel, int control, int event,
 short int  t, ncard, vid, chan, idchan,id, pn, res;
 long cp, img;
 switch (event)
  case EVENT_COMMIT:
  status = GetObjHandleFromActiveXCtrl (panelHandle, PANEL_XV2003, &obj);
  status = SFILELib__DSfileDeinit (pic, NULL);
  status = XV2003Lib__DXv2003Init (obj, NULL);
  status = XV2003Lib__DXv2003GetTotalSlot (obj, NULL, &slot);
  status = XV2003Lib__DXv2003GetDeviceNum (obj, NULL, slot, &dev);
  status = XV2003Lib__DXv2003CreateVideo (obj, NULL, dev, 230, 340);
  status = XV2003Lib__DXv2003OpenSlot (obj, NULL, slot, long H_Wnd);
  status = XV2003Lib__DXv2003GetTotalCard (obj, NULL, &ncard);
  status = XV2003Lib__DXv2003IsVidPresent (obj, NULL, slot, &vid);
  status = XV2003Lib__DXv2003GetDevID (obj, NULL, slot, &id);
  status = XV2003Lib__DXv2003GetChnID (obj, NULL, slot, &idchan);
  status = XV2003Lib__DXv2003GetChannelNum (obj, NULL, dev, &chan);
  status = XV2003Lib__DXv2003Run (obj, NULL, dev);
   break;
 return 0;
Answers of variables:
obj = 41762400
slot = 0
dev = 0
ncard = 1
vid = 1
id = 0
idchan = 0
chan = 2
In my opinion the value of variables indicate that the board is working.
The parameters of OpenSlot function is :
HESULT XV2003Lib__DXv2003OpenSlot (CAObjHandle ObjectHandle , ERRORINFO *Error_info, short N_Slot, long H_Wnd);
I think that with this function the image will show on the screen and but I don't know what to do with the parameter " long H_Wnd"
I'd like to know if someone can help me capture the image and put it on the screen.
tks
Andre G.
(3,009 Views)
Hi Andre,
As it's an ActiveX object, we cannot do a lot to help you. You need to check the ActiveX object documentation to understand the inputs and outputs parameters. Something you need to check is if the image will be sent to your application by a method or event in the ActiveX control.
Regards
Alisson Kokot
(2,954 Views)
