LabWindows/CVI
CDotNetInvokeGenericMember throws Exception
I am new to LabWindows and I have to fix a bug in a software, which is written by someone who left the company. But I can not even compile very properly.
There are some DLLs, written in C# and built in Visual Studio 2013. If I run the program it gives an error :
NON-FATAL RUN-TIME ERROR:   "c:\...\udp.net\UdpDotNetCommunicator.c", line 47840, col 5, thread id 0x00001D38, function id 2:   Function CDotNetInvokeGenericMember: (return value == -6571 [0xffffe655]). The target invoked by the LabWindows/CVI .NET Library threw an exception.
According to    .NET Library Error Codes   (http://zone.ni.com/reference/en-XX/help/370051M-01/cvi/libref/cvidotnet_library_error/ it is   The target invoked by the LabWindows/CVI .NET Library threw an exception.
But I have really no idea.
And the source code in UdpDotNetCommunicator.c line 47840 is so:
    __errChk(CDotNetInvokeGenericMember(
        __assemblyHandle,
        "ControllerBoard.Communication.UdpCommunicator",
        __instance,
        CDOTNET_CALL_METHOD,
        "ReadRegister",
        0,
        0,
        4,
        __parameterTypeNames,
        __parameterTypes,
        __parameters,
        &__returnValueTypeId,
        &__returnValue__,
        __exception));
 What can I do? It gives this error 20 times and continues to run if I click "Continue".
Thanks.
(5,219 Views)
this error can happen when the library was not correctly registered (that it is not found in the GAC). Have you already seen the following thread ? http://forums.ni.com/t5/LabWindows-CVI/What-is-the-labwindows-cvi-equivalent-to-the-net-constructor/...
I hope this helps.
Aurelie
(5,179 Views)
