LabWindows/CVI
C++ code development with CVI
I know this topic has been asked several times in the past, but CVI compiler was an ANSI C compiler and didn't support C++ (see here or here for example).
Some documents on how to integrate C++ dll into CVI are available on NI website (for example here).
But starting from CVI 2013 NI compiler has been replaced by CLANG/LLVM compiler, and this is a C/C++ compiler (http://clang.llvm.org/).
Based on this huge modification, can Labwindows/CVI be used to develop C++ code?
Would this be possible in the future?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(15,466 Views)
Hi Vix,
LabWindows CVI 2015 and or previous versions support only C.
Look at the main site http://www.ni.com/lwcvi/. There is information related to ANSI C.
(15,433 Views)
Hi Dagaror,
as I wrote in my first post I'd like reading some detailed info on C/C++ development with CVI based on the latest CLANG compiler used by CVI.
As far as I understand, CLANG is a C/C++ compiler so I wonder why CVI can't compile C++ code.
Maybe this can be a nice product suggestion for the Idea Exchange forum, but I need to know more detailed info.
Vix
Using LV from 7
(15,424 Views)
Hi Vix,
Supporting C++ entails far more than just the compiler. For example: the standard C++ library (including templates, etc...), the APIs of all the standard CVI libraries, the source editor (auto-indentation, coloring, etc...), code-generation from the various wizards, memory runtime checking, debugging, etc... so, even though the compiler does support it, for all of CVI to support C++ is still an extremely large undertaking that has to be weighed against other, competing work that's going into CVI.
I agree that this is something to should be taken to the Idea Exchange.
Luis
(15,214 Views)
"... that has to be weighed against other, competing work that's going into CVI."
Like what? Fixing an a4 sized list of bugs and calling it a major release? You gotta be kidding me.
(15,145 Views)
Who wants to support this feature can add kudos and/or comments to this idea in the Idea Exchange forum.
This one is almost the same, but I'm not convinced of the reasons detailed there  (so I preferred to open a new idea).
Vix
Using LV from 7
(15,111 Views)
