LabWindows/CVI
Button enable
i will enable and dissable a button.
The button ist visible but the color should to grey.
The command is blocking too.
(4,624 Views)
If I understand your question correctly, you want to know how to disable a button, without making it invisible to the user. To do so, use the SetCtrlAttribute function.
To disable the button: SetCtrlAttribute (panel, button_ctrl, ATTR_ENABLED, 0);
To enable the button: SetCtrlAttribute (panel, button_ctrl, ATTR_ENABLED, 1);
You can use the ATTR_ENABLED attribute for almost any control type.
(4,620 Views)
ATTR_ENABLED refers to timers only, disabling them and stopping the callback.
You should be using ATTR_DIMMED
(4,615 Views)
The simplest way is to use SetInputMode (panel, control, mode);
Setting mode = 0 will disable the button and grey it out (the same as SetCtrlAttribute with attribute ATTR_DIMMED and value 1); setting mode =1 qill enable the button.
(4,601 Views)
