LabWindows/CVI
Build file
I have inherited some labwindows cvi code and when the .prj file is opened a build of the file automatically happens. I would like to manually do the build by choosing the correct options from the pulldowns as normally done. This also works. I want to eliminate the automatic build from occurring when the file is opened. Why is this happening? Is there a setting that I can turn off so this will no longer occur?
Mark
(1,375 Views)
Does it happen with new created projects too ?
Have you tried opening the project from labwindows (file > open > project) ?
(1,221 Views)
