LabWindows/CVI
Bug in the UIR Editor
In the attached File there are four Text-Messages placed on the "PLGOPTS" Panel with the Constants "TEXT1", "TEXT2", "TEXT3" and "TEXT4". I place the four panels as tabs on the PRGOPTS-Panel. Displaying the panel affects, that one or more of the Text-Messages isn't diplayed. Also creating it new or copying with copy-paste doesn't help.
(3,026 Views)
I wasn't able to reproduce your problem exactly, because the use of the constants are not clearly defined.
But i was successfull to insert your Panels correctly in a Tab and could switch between the Tabs without seeing any problems.
Did you try the "EasyTab_ConvertfromCanvas" function as well?
Best Regards,
Evrem Yarkin
Application Engineer
NI Switzerland
(3,026 Views)
Well, I didn't try the "EasyTab_ConvertfromCanvas" but I found a workaround for the problem. I think the Default settings of the Text-Messages don't work well. When I set the text programmatically it works.
(3,026 Views)
