LabWindows/CVI
Buffered Period Measurement using Traditional API in LabWindows
Does anyone have sample code for buffered period measurement using the NI-DAQ traditional API in LabWindows CVI?  I am using a PCI-6024e card.  I can set up the process with:
GPCTR_Set_Application (deviceNumber, ND_COUNTER_0, ND_BUFFERED_PERIOD_MSR);
but I'm not sure where to go from here. Thanks in advance,
andgate
(3,246 Views)
You may find useful this example that performs this operation on a 660x card. Hardware is different from your card (NI-TIO instead of DAQ-STC) but the code could be a good framework for developing your application.
(3,236 Views)
Hi andgate,
There are also examples included with the Traditional NI-DAQ drivers for Visual C.  They can be found in the following directory:  ...\National Instruments\NI-DAQ\Examples\VisualC\Ctr
Within this directory there is a C source file titled "STCsingleBufPeriodMeasure.C".  This particular example should give you a good start in setting up your application.
Andrew W
(3,217 Views)
