LabWindows/CVI
Breakpoint on attribute change to a control
Hello all again,
Is there a way to set a breakpoint so that the program stops if anything
happens on a control, like an attribute change ?
The reason is that I have a control that behaves erratically in a complex
app. I suspect there must be a bug with the wrong panel number somewhere and
this unfortunate control is the recipient of some command not destined for
it, but I have hundreds of panels and cannot find it.
I looked at the resource tracking, but I have no idea how this works.
And if it's not possible, maybe some addition to SetBreakOnLibraryError,
something like SetBreakOnControl(panel, control, AttributeList) or similar.
Guillaume Dargaud
http://www.gdargaud.net/
(3,178 Views)
This could be a good tool I have searched for several times... and never found! Smiley Frustrated
You should post it to CVI Idea Exchange board: I will kudos it immediately! Smiley Wink
(3,175 Views)
Done:
http://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/Set-breakpoint-on-
control-attribute-change/idi-p/1897055
Guillaume Dargaud
(3,163 Views)
