LabWindows/CVI
Boolean variable to/From Test Stand
I have this question posed in two locations, Test Stand and Labwindows/CVI.
I am migrating old code from LabView 7.1 and Test Stand 2.0.1 to Test Stand 2010 SP1 and Labwindows/CVI 2010 SP1.
In order to build a distribution pack I need to get rid of ALL the old code.
I have a lot done but stuck on the following.
From CVI I have Simple CVI TestStand UI almost working as the old one did but for one part.
I have a Test Stand Boolean variable, StationGlobals.Debug, which will get set True or
False by a CVI UI binary switch.
I need to read and write to this variable out and into Test Stand so it can be set in accordance with the CVI UI binary switch.
How do I go about this?
Thanks for your time
Simon
(3,281 Views)
This is a repeat post that has had answers posted at~:
http://forums.ni.com/t5/NI-TestStand/Boolean-variable-to-From-Test-Stand/m-p/1945303
Liam A.
(3,270 Views)
