LabWindows/CVI
Big CVI Problem...
This morning CVI put me up side down... 🐵
In more then 4 years I have never seen that...
Ok This morning I wanted to add a *.lib file in my projet... So open the Add files to projet window... and at my biggest suprise... NO OK, REMOVE and REMOVE ALL COMMAND BUTTON... only the ADD AND CANCEL...
I tried to deinstall every and reinstall it NO CHANGE ????????!!!!!!....
I'm going crazy...
Please help
Best regards
Steph
Message 1 of 8
(4,582 Views)
Sorry Steph...
What version of CVI ?
Chris
Message 2 of 8
(4,582 Views)
it is CVI 5.5... on windows 2000...
the worse... I tried to install on and other machine and it work fine ???????!!!!
Message 3 of 8
(4,582 Views)
Steph...
I just checked on my CVI5.5 and its Ok there too. I suspect its probably making a lower level call into a Windows Lib or something (for the file dialog box).
Try reinstalling Service Pack 1 or 2 on your W2K.
Have you installed any new software lately ?
Chris
Message 4 of 8
(4,582 Views)
Hi Steph,
The Add Files To Project... dialog is an inherited and slightly modified Windows system dialog. CVI adds the Directory History field, the Selected Files field, and the Ok, Remove, and Remove All buttons to this standard system dialog.
We have never seen this issue before in house, but there may very well be something wrong on your particular system that causes these buttons to not show. I would like you to consider the following questions and troubleshooting techniques in order to diagnose the problem a little better for us:
1) Are the Directory History and Selected Fields also missing?
2) If you open the File >> Open... menu selection dialog, does it have the Directory History field in it as well? (this is another modified system dialog t
hat we use and I am curious about its behavior)
3) In the Add Files to Project... dialog, if you try tabbing from one control to the next does it appear as though when you hit tab that one control loses focus and it takes a couple of more tab-strokes to return focus to one of the visible controls in the dialog?
4) If the latter theoretical situation does happen and you hit tab so that no visible control has focus and you then hit the enter key, what happens? One hypothesis is that the controls are there but they have been moved offscreen.
5) In any case we may need to know what OS you are using to try giving you more suggestions on, so please make sure to answer this as well.
Jason F.
www.ni.com/ask
Message 5 of 8
(4,582 Views)
Thank...
I gave a ring to NI support... the problem have been seen before... they have some record, picture of the UI, same as the one I have...
It look like it problem with inter language ... W2K in french... and CVI in english... but don't know if there a fix for it...
Thank for your time Chris...
Best Regargds..
Steph
Message 6 of 8
(4,582 Views)
I'll try every thing tomorrow... but one thing that I'm is that shortcut key work... and the same problem exist with the "include file select directory dialog box... NO OK button...
By the way the OS is windows 2000
Best Regards
Steph
Message 7 of 8
(4,582 Views)
I forgot that point... Cancel button that is in add files to projet dialog box is in french... ???? and the add button still in english...
Later
Steph
Message 8 of 8
(4,582 Views)
