Hello Luis,
Thanks for both replies. It is (I think) fully clear to me now.
For the many people that also took the effort to look at the content of this thread, I will summarize:
I will have to keep working with version CVI6, within projects where I work together with people that also use CVI6.
I can install CVI7 at my computer where CVI6 is already running, but I have to install it in a different subdirectory. (Note that the runtime-engine in the windows-system subdirectory will be replaced with the newest version.) With this CVI7, I can create a distribution kit with the runtime engine from CVI7. If I use CVI6, it will create a distribution kit still with the runtime engine from CVI6.
As the runtime engine is upwards compatible, executables from CVI6 as well as from CVI7 will work fine with the newest runtime engine. So I can make for one computer, executables with either CVI6 or CVI7, provided that this computer has the newest runtime engine.
If I save any UIR with CVI7, I need CVI7 when changing it again, and I need runtime engine from CVI7 at the computer that runs the executable.
Regards, Jos
