LabWindows/CVI
Basic question
i know now how to write simple CVI application with callback functions. My question is where i put my main code ( when there are not events ).
For example i write some application that all time draws something. Where i put code of drawing?
I need some function that executes all time that there are not events.
(3,699 Views)
Well, you have two options:
Option 1: Don't use RunUserInterface in main(). Instead write your own loop that does your normal code and calls ProcessSystemEvents() in a loop to monitor for events occurring.
Option 2: (RECOMMENDED) Use a Timer control. A timer control will generate events over and over at a regular interval in milliseconds that you can handle in a timer callback. This allows you to use the normal event processing and also run some other code ever 1 to N milliseconds.
Hope that helps,
Chris Matthews
(3,699 Views)
Thanks, Chris.
I also readed in help that there is "event" EVENT_IDLE.
If i understand, i can receive this message as callback function if there is not event and to put there my code. How can i enable this "event"?
(3,699 Views)
No, you shouldn't use the EVENT_IDLE. That was provided before we had timer controls in CVI. As noted in the help, you should use timer controls instead of the obsolete EVENT_IDLE. Below is an excerpt from the CVI help:
Description: Idle events are sent to the main callback function on a regular basis, as long as LabWindows/CVI processes events. You can set the rate at which idle events occur using SetIdleEventRate. This event is now obsolete; it is recommended that you user timer controls.
Chris
(3,699 Views)
