LabWindows/CVI
Basic String Manipulation Question
I have this  c:\test\basic\testfile.xls
and I want testfile.xls extracted string.
I did it the hard way and wrote my own function
void ConvertFilename( char *path, int count)
char tmp[MAX_FILE_CHAR];
int found =0,i=0,j=0;
    for (i=0; i < count; i++)
     tmp[i]= (( char ) *path++ );
     if ( tmp[i] == '\\' ) found = i;
    for (j=found; j < count; j++) *(path ++) = tmp[j];
 *(path ++) = 0;
Is there an easier way in CVI?
(4,783 Views)
There is SplitPath() in the utility library
(4,778 Views)
there is also the Shell Lightweight API library, which is part of the Windows SDK. add "shlwapi.lib" into your project and #include "shlwapi.h" from your source file. in this library, the path manipulation function generally starts with the word Path. for example, PathCombine() is the function to merge 2 pathes together.
(4,772 Views)
Or you could also just use the C string manipulation basics:
char *lastSep= strrchr(path, '\\');
return lastSep ? ++lastSep : path;
Mert A.
(4,767 Views)
(a little note: although this is the simplest and most efficient implementation, you should never ever roll your own path manipulation function, because you will always forget one or another not-so-special case)
(4,739 Views)
Markus, excellent suggestion, works great !!
Thank U all
Diego
(4,734 Views)
