LabWindows/CVI
Automatic SQL (maps), how to query?
hi everyone, i'm trying to use the Automatic SQL (maps) instead of the Explicit SQL and it's very easy to write and read from the database just writing the column name and binding it... but... how can i do query with this type of connection?
for example i have a table with
- DateTime
- Result (OK, KO)
and i want to get only the OK value within a date.
With Explicit SQL i would have done
SELECT * FROM [TableName] WHERE DateTime BETWEEN #2016-03-01 00.00.00# AND #2016-03-02 00.00.00# AND WHERE Result = OK
but how to do it with the Automatic SQL (maps)?
thank you
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
Message 1 of 8
(5,628 Views)
Hello holly,
Did you write some LabVIEW code which does this operation?
Kind regards,
Pep
Message 2 of 8
(5,614 Views)
pep, please note that we are here in the CVI board: people are not supposed to know graphical programming Smiley Wink
Message 3 of 8
(5,608 Views)
Ops, it's my fault.
Anyway, if he can provide us some code we can better help him to solve the issue.
Kind regards.
Message 4 of 8
(5,606 Views)
hi pep91, i haven't problem with my code it's only a question if it's possible to do some query using the "Automatic SQL (maps)"
Message 5 of 8
(5,586 Views)
Accepted by topic author holly7787
Hi holly,
is this document useful? http://zone.ni.com/reference/en-XX/help/370502D-01/cvisqlref/usingautosqlmaps/
Kind regards.
Message 6 of 8
(5,582 Views)
After the program maps all the columns, call DBActivateMap to construct the SQL SELECT statement, execute the statement, and bind the columns to the variables.
after reading this i think it's impossible. thank you
Message 7 of 8
(5,576 Views)
Glad I could help you, not so happy that you cannot do it.
Kind regards.
pep
Message 8 of 8
(5,573 Views)
