LabWindows/CVI
Attribute list invisible in fp of IVI driver
I've written an IVI driver and the associated fp file but when other programmers want to use my fp file they don't have any attribute in attribute list of the Set/Get attribute function panel window. It works fine when the fp file is in the development directory but not otherwise. I don't want to give the source code to the others because, for me, that's not the aim of a fp file. So is there any solution to my problem? Thanks.
(2,927 Views)
When you press the ENTER key or click on the "..." button to select an input from a list of attributes for a function panel parameter, a callback function is called to display the dialog box. This callback function is located in a DLL. You must deploy this DLL with your fp file to keep this functionnality.
For more information, please see the "NI LabWindows/CVI Help" in "Using LabWindows/CVI>>Instrument Drivers>>Building Function Panels>>Editing a Function Panel Window>>Customizing Controls".
(2,896 Views)
