LabWindows/CVI
Asynchronous Sockets
I'm using LabWindows 7.0 and I wanted to implement asynchronous sockets. Based on the documentation I am finding for winsock, I need to have a "window message" in order send/receive information using the asynchronous model. Does LabWindows support the "window message", or is there another way of using asynchronous sockets for IP over 1394?
(3,139 Views)
If you have the full development system, you have access to the SDK functions and can do just about anything you want via CVI.
The question I have is, would one of the existing network communication libraries (TCP/IP, Datasocket) perhaps serve to solve your problem?
Basically the way I look at it is "why reinvent the wheel?" If an existing tool will do the job, I use the tool. If not, I always try to find code that I can reuse or adapt for my purpose before I go off and roll my own.
The first virtue of the programmer is laziness. Smiley Wink
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(3,133 Views)
