LabWindows/CVI
ArrayToFile With String Table saving only commas
int rows;
			char **table_array;
			char save_file_name[MAX_PATH];
			if (FileSelectPopup ("", "*.csv", "*.csv", "Select File Name to Save", VAL_SAVE_BUTTON, 0, 1, 1, 1, save_file_name) > 0) {
				GetNumTableRows(mainHandle,PANEL_LOGGING,&rows);
				table_array = malloc(rows*6*sizeof(char *));
				GetTableCellRangeVals (mainHandle, PANEL_LOGGING, MakeRect(1,1,rows,6), table_array, VAL_ROW_MAJOR);
				ArrayToFile (save_file_name, table_array, VAL_STRING, 6*rows, rows, VAL_GROUPS_TOGETHER, VAL_GROUPS_AS_ROWS, VAL_SEP_BY_COMMA, 10, VAL_ASCII, VAL_TRUNCATE);
				FreeTableValStrings(table_array,rows*6);
				free(table_array);
			break;
Doing this outputs a file with 5 commas on two lines (3rd line empty).  But no data/strings are saved within them.  (CVI 2010SP1)
The data in the array is sorted such the first 6 elements are row 1, next 6 are row 2, etc.
Any ideas?
(4,700 Views)
Hi ngay,
CVI2010 should be able to treat strings, at least this datatype is available in the function whereas it was not till CVI2009 (see function help for 2010 and 2009) so I don't understand what's happening.
I don't have a 2010 machine ready at the moment but I can offer you an alternative using the clipboard:
	int	fH = 0;
	char	*table_array;
	ClipboardPutTableVals (panel, Impo_c, VAL_TABLE_ENTIRE_RANGE);
	ClipboardGetText (&table_array, NULL);
	fH = OpenFile ("test.txt", VAL_WRITE_ONLY, VAL_TRUNCATE, VAL_ASCII);
	WriteFile (fH, table_array, strlen (table_array));
	CloseFile (fH);
	free (table_array);
 This code actually saves the table content into the clipboard, then retrieves it and writes it to a file. Text is automatically separated into rows / cols with tab as column separator.
Note that I have used VAL_TABLE_ENTIRE_RANGE to select all the table, but yo can tailor this parameter to the exact table range you want (actually that macro translates to the appropriate MakeRange statement).
A benefit of using the clipboard is that you can retrieve data of several data types (e.g. numeric and strings, don't know what it does with images) in a single pass.
(4,691 Views)
did you ever get the ArrayToFile to work with the string words
(4,443 Views)
