LabWindows/CVI
Application error (0xc0000005)
removal of prior versions and Beta CVI, Post install 9.0.1 none of the CVI precompiled or debug projects will function, all crash with this message (2 times) then a Fatal Runtime error on a general protection fault
Message 1 of 23
(6,836 Views)
Lets start from the beginning. I'm not entirely sure whats going on here. You had previous versions of CVI, including possibly a beta. You then removed them and then installed CVI 9.0.1. Now none of your projects will compile or run, including the exe's. Is this correct?
I'm re-attaching the image from the power point so those forum members without the program installed can view the image.
If so can you run any of the example programs listed under  C:\Users\Public\Documents\National Instruments\CVI90 ? Do you get the same error.
I would recommend getting a log of the crash http://decibel.ni.com/content/people/nickb/blog/2009/06/10/generating-crash-dumps-for-analysis-by-na...  .
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
Message 2 of 23
(6,806 Views)
Great suggestion, I did that and the error does not generate a .dmp file in the directory, just the same ole pop-up error panels as before... something is seriouslly wrong with this system.
I also tried a example code as suggested. same results.
Cheers!
ChipB
Message 3 of 23
(6,800 Views)
Chip, can you try running the dump program while you are double clicking the exe that was built by CVI. Preferably do this on one of the examples. Also, can you let us know exactly what version of CVI this is happening in 9.x.x (xxx). If you run the dump program while you are building the project in CVI, then CVI will catch the crash instead.
Message 4 of 23
(6,780 Views)
It is still not creating a .dmp file when crashing, loading and building the exe of an example file has the same results as running a pre compiled cvi program
Ver 9.0.1 build 375
ChipB
Message 5 of 23
(6,776 Views)
So to confirm, if  you run the executable without ever opening the CVI environment you do not get a .dmp ?
Message 6 of 23
(6,761 Views)
Correct. Is my laptop terminal? Smiley Happy Have to get a new one!
Message 7 of 23
(6,754 Views)
I would like you to try the dr. watson integration procedure again and see if we can try to caputer a crash dmp one last time. In addition I would like follow a troubleshooting step from this forum post http://forums.ni.com/ni/board/message?board.id=180&thread.id=44967&page=1
We will need to open CVI, wait until the crash happens, then open the modules window (Window»Modules) and find which module contains the crash address.
When this happens can you post a screenshot.
Message 8 of 23
(6,710 Views)
Attached... Windows file corrupt? msctfime.ime???
Message 9 of 23
(6,707 Views)
Aisc,
It looks like its crashing in the NTDLL http://www.computerhope.com/issues/ch000960.htm which is part of the operating system. Can you maybe try linking dr. watson again and maybe trying a few different EXE's (with CVI closed). The crash dump file is a crucial piece to this puzzle.
Message 10 of 23
(6,682 Views)
