LabWindows/CVI
Application crash
I finally isolated my problem to the use of __FUNCTION__ (a predefined macro) in the following code:
#define debug_printf(debug,lvl,x) do { \
                                        if ( ! __debug_printf_check( debug, lvl ) ){ \
                                            __debug_lock(); \
                                            __debug_printf ( "%s:%s:%d: ",__FILE__, __FUNCTION__, __LINE__); \
                                            __debug_printf x ; \
                                            __debug_unlock();\
                                    } while(0)
where __debug_printf is defined as follows:
void __debug_printf(const char * format, ... )
    //int diagnostic = 1;
    va_list ap;
    //if (diagnostic)
        //return;
    if (output_enabled & CONSOLE_OUTPUT){
        va_start (ap, format);
        vfprintf ( stderr, format, ap );
        va_end(ap);
    if (output_enabled & UI_OUTPUT){
        ui_debug_printf( format, &ap);
        va_end(ap);
    if ( output_enabled & FILE_OUTPUT){
        va_start (ap, format );
        if (fp != NULL) vfprintf ( fp, format, ap );
        va_end (ap);
The program wouldn't crash on every invocation of __debug__printf, but it would consistently crash at the same point in our code.  __FUNCTION__ is actually redundant, since FILE and LINE are given, so I removed any reference to __FUNCTION__ and the crash problem disappeared.  It was a pain to find this bug.
Message 21 of 22
(1,223 Views)
Are you using C99?
C99 added the   __func__   mechanism, I think the  __FUNCTION__  macro is something NI did.
Even if you're using C99, it's not certain that NI would have implemented __func__.    __func__ is actualy a block scope local (stack) variable, not a macro, so you may get better behavior with it if it's available.
But like you say you know the file and line so it's not really needed.
Message 22 of 22
(1,220 Views)
