LabWindows/CVI
Append file name using FileSelectPopup() under Windows VISTA
Hi
I was using FileSelectPopup() without any problem before Windows Vista came in town.  In Vista, if I click on an existing file name, let say Logfile1.tem, the file name "Logfile1.tem" appear in the File Name box.  Then if I change this string to Logfile2.tem, the FileSelectPopup() function will return "Logfile1.tem" anyway.  This behaviour is not possible using XP.  Using Vista, if I want "Logfile2.tem" to be return, I have to type the whole file name, if I click on an existing file name, this is what will be return whatever I will type in the file name box after.
This is how I call File SelectPopup:
stat = FileSelectPopup (".", "*.tem", "*.tem", "Select logging file", VAL_SAVE_BUTTON, 0, 1, 1, 1, pathName);
I just moved from CVI 8.0 to 8.5 to fix others minors  "Vista bug" but this one still alive...
Any idea ?
(4,815 Views)
Good catch!  I too see this behavior in Vista in my application.  I note that even if I press <Tab> after editing the name, it still does not take the edited name. However <F5> (which refreshes the file listing) does cause it to pick up the edited name.
I'll be monitoring this thread with interest.
--Ian
(4,783 Views)
I echo the appreciation for the wonderful catch; I've reproduced this behavior as well. This was reported to R&D (# 4H9HQTH9) for further investigation.  We really appreciate the feedback!
Derrick S.
Product Manager
NI DIAdem
(4,769 Views)
I'm having this problem, too.  What's the solution?  Upgrade to CVI 9.0?
Josh
(4,354 Views)
Hey Josh,
After reporting this issue to R&D as I mentioned in my previous post, they have fixed the bug for the most recent release of the software.  You will need to upgrade in order to get this fix.
Derrick S.
Product Manager
NI DIAdem
(4,352 Views)
OK, thanks.
(4,350 Views)
