LabWindows/CVI
Any idea for moving control instead of using "EnableExtendedMouseEvents()" ?
As to the cvi's help document, the function of "EnableExtendedMouseEvents()" is obsolete, but how to use the "EVENT_MOUSE_POINTER_MOVE, EVENT_LEFT_CLICK_UP" event to realize moving a control?
David
(3,120 Views)
Have you considered using the Run-time Movable Control instrument?
Here you can find a sample program that demonstrates its usage.
(3,115 Views)
Hi Roberto,
Is there a way to move a control using the mouse but not to hold the "ctrl" key?
David
(3,093 Views)
You could create your own routine by sitting in a loop reading GetGlobalMouseState () or possibly GetRelativeMouseState() to read the mouse position and button status, and then use SetCtrlAttribute() to move the control around on the user interface.
(3,072 Views)
