12-13-2016 04:51 AM
Is there any way to show the machine alarms?
Thanks.
12-13-2016 05:04 AM
Which kind of alarms are you intending? If you can detail a little more what is your goal we can try searching for the appropriate solution
12-13-2016 05:19 AM
I want to display an alarm message when a PLC bit is 1 or true
I want to display an alarm message when a PLC bit is 1 or true. Like in a human machine interface (HMI).
Do you understand it?
12-13-2016 10:44 AM - edited 12-13-2016 10:46 AM
Yes, this way your question is more clear. Nevertheless, it implies at least two different aspects:
Since they are very different, which of them are you interested to? And did you already try something to solve your problem?
Item #2 can be easily solved with either a MessagePopup or a text control on the screen. Item #1 heavily depends on the PCL you are using.
