LabWindows/CVI
Adding USB Driver Install to Installer
Is there a way to get the LabWindows/CVI created installer to install the custom USB driver for VISA instead of manually copying the .inf file to the proper directory and right clicking to then install it?
(3,187 Views)
If you have an installer (setup.exe or similiar) for this task, you can add them to the distribution kit, which is created by CVI. Via context menu inside the "edit installer" dialog you can specify "launch after installation".
hope that helps
Peter
(3,182 Views)
