LabWindows/CVI
Add two strings
Hi everybody!
First i'm sorry for my English because i'm French.
So i would like to add to strings. For exemple, I have : "GPIB0::13::INSTR". 13 is in a char array called ADD.
So I would like to do : "GPIB0::" + ADD + "::INSTR" but I can't!!!!
How can I do this please?
Thanks for your answer!
Tonave
(4,787 Views)
Accepted by topic author Tonave
You can add strings in C in the following way:
    char str [256];
    strcpy (str, "First string " );        // Initialise string to first bit
    strcat (str, "Second string " );       // 'add' second bit
    strcat (str, "Third string" );         // You've probably got the idea by now...
Although I prefer the more general method of constructing strings:
    sprintf (str, "%s %s %s", "First string", "Second string", "Third string" );
because this gives much more flexibility - see the help for sprintf() for a fuller description.
JR
Edit: to try to get rid of the smilies!
Message Edited by jr_2005 on 03-12-2009 02:57 PM
(4,783 Views)
Ok it works!!!
Thanks a lot jr  Smiley Wink
(4,778 Views)
I simply add that in case you prefere there is a french speaking forum community here. You can access it via the "Select community" selector in the upper right corner of the page.
(4,773 Views)
For sure I prefere!
Thank you!
(4,770 Views)
