LabWindows/CVI
Add fonts
Hi all,
i need to add fonts to CVI for barcode (specially 128). I copied the polices into Windows/Fonts and i suppose that CVI will detect it after that. While, he dont. What shall i do?
Best regards.
Message 1 of 12
(5,456 Views)
FibiIA,
There is a useful Help document for CVI that explains the different ways of using fonts in CVI.
LabWindows/CVI 2012 Help » Using Fonts
How are you attempting to use this font in your application?
Jared A.
Message 2 of 12
(5,435 Views)
Hi Jared,
I need to put a text which its font is a bar code 128. So, i copied into windows/fonts and i expect that CVI will load it as do word or excel. I will check the help of CVI if there is a solution.
Thank you for replying and i will appreciate if you can help me more.
Best regards.
Message 3 of 12
(5,427 Views)
You should be able to display barcode fonts by changing the Text Style for most user interface text controls. Below is a screenshot of a user interface displaying barcodes.
I did this by opening the Edit window of my Text Box Control and selecting Text Style.
Then I changed the Font to a barcode font.
Hope that helps.
Rohama K.
Message 4 of 12
(5,408 Views)
Hi Rohama K,
The fact is that i don't find the font of bar code 128 in the list of fonts when openning the window of Text Style.
I need find the way of loading a new font to labwindows.
Best regards.
Message 5 of 12
(5,400 Views)
To get my font to show up, I installed it by following these directions. What OS and LabWindows/CVI version are you using? Are you able to see the font in Word or Excel? Can you attach the font so that I can try?
Rohama K.
Message 6 of 12
(5,384 Views)
Hi Rohama K,
I use Windows 7 and LabWindows/CVI 2010. In word and excel i see the font.
Message 7 of 12
(5,366 Views)
here the font
Thank you
Message 8 of 12
(5,363 Views)
FibiIA,
I attempted to open your attachment (C28TGCFZ.zip) but it said the .zip file was invalid and could not extract any files. Could you please try re-attaching?
Jared A.
Message 9 of 12
(5,340 Views)
Hi jallen88,
Here's the font.
Message 10 of 12
(5,329 Views)
