LabWindows/CVI
Activex Class object Question
I have a question about how LabVIEW "sees" activex controls.  I have a dll, which displays createable objects in the activex menu.  LabVIEW sees the type library name and I can create methods and property nodes.  Now, when I load the same dll into VB 2008, I get the self-registration error, eventhough the dll was manually registered using regsrv32.  What is LabVIEW doing to be able to "see" the activex controls inside the dll?
(3,359 Views)
Shivels:
This is the LabWindows/CVI forum.  Have you posted your question to the LabView forum?
(3,353 Views)
Whoops, I was reading about activex in LabVIEW/CVI when I posted the question.  I will post over there, thanks.
(3,351 Views)
