LabWindows/CVI
ActiveX TreeView Insert Images
I'm using the ActiveX Treeview Control under Labwindows CVI 6.0. It works fine.
Now I want to insert images to the tree.
I could not find out how to do it.
Does anybody has a good example or description
(3,244 Views)
I've already di that. The better way is to add an ActiveX control on your panel : ImageList. After that, you can edit your control and create a list of images. In your code you can associate the TreeView and the ImageList. When you're adding an item, you can specify the immage associated with by using an index, for example.
(3,244 Views)
